I have the KayaCast, and have been using it with my Formlabs casting.
I’ve had it since maybe 2015, and it’s a great system. I like that it can take both solid and perforated flasks, so that flexibility is really nice. One drawback…when I bought mine, it came with a single perforated flask, and the necessary adapter for the drop-in chamber. I found other perforated flasks online, and just assumed that they would fit…THEY DID NOT.
I learned this when I had a large run burning out in the kiln. Fortunately, I had worked with a local metal shop that has a water jet cutter, and they were able to quickly cut a couple of steel plates with the right sized holes. If you decide to get a KayaCast and need those CAD files, I’m more than happy to share them. I used a fiberglas-reinforced baking mat to make the gasket. The metal adapter doesn’t have to even been precise…there is a little wiggle room, so even if it were cut with a regular cutting torch, it should work.
For me, it was the right price…a larger automatic system wasn’t in my budget because I only do single pieces or limited runs. On my larger runs, I think I’ve been able to cast 60 charms or so in one flask? I’m using Neutec sprues/bases with the perforated flasks. Just make sure that the flasks fit…check to see what larger perforated flask is included…that diameter is what you’ll want to stick to.
I took a class from Kate Wolf (wax carving goddess…her tools work GREAT on resin), and I asked her if she preferred a centrifugal setup or vacuum. She said vacuum. You’ll have to experiment to get the metal temperatures right, but it will depend more on your flask temperature when it comes out of the kiln and metal temperature if you’re doing fine work. My biggest issues have been what I believe to be incomplete ash burnout, but I’ve seen some folks using a vacuum on the flasks, returning them to the kiln so they can come back up to casting temperature. That residue can cause “crustiness” on the surface of your pieces. You’ll also want to add boric acid to your investment to strengthen it.
There are versions that have the vacuum table only, but the one I think you’re considering has the drop-in vacuum as well…I recommend that version.
What quantity will you be casting?
