The resin overflowed during the process, resulting in spillage onto the components and the base table
hello,
My printer had a major resin overflow, and the resin spilled over the stepper motor, lead screw, and some of the sensors. I also suspect that some resin may have reached the internal PCB. An entire resin tank emptied without triggering any error message.
Does anyone have a solution for how to safely and thoroughly clean everything? Any tips or steps to prevent further damage would be greatly appreciated.
Monesh, JAPAN
Hello, here is the official informations from Formlabs on the subject :
Cleaning after an extensive resin spill (Form 3/Form 3B)
Dear @monesh_kaneko, sorry to read that you’ve had an issue! As @serret already suggested, please do a thorough cleaning and print an optics test after to see if everything works as it should. If you’re still having issues after cleaning or you need help investigating what caused the spill, please contact our support team here.
