Tank reprogramm
i abrusely reprogramm the tank from claer v1 to white and i wanted to reprogramm it into v2 claer
can i chanch this?
Hi @Engels
Thank you for writing in.
There are different ways to reprogram a resin tank depending on what type of printer you have.
You can find the articles for each printer generation on our support pages (this link will get you right to those).
What will work on almost any generation of Formlabs printer is to insert the misprogrammed tank, a cartridge of the type you want to program it to and sending a file to the printer of the same type as the cartridge.
Start that print and the printer should give you a “tank cartridge mismatch” error. If the file and cartridge are the same and only the tank is different, you will find a “skip” or “continue” option on the screen and the printer will reprogram the tank and start the print.
Kind regards
Jakob
Thank you ,but my 3 B printer says start print ore cancel but maybe i do smthing wrong
Hi @Engels
Thank you for replying.
What happens if you go into the printers’ menu → Maintenance → Reprogram Tank?
Kind regards
Jakob
Mine did this for the first time today. I’m currently running a print job on my Form 4 and the tank is still showing as a mismatch even though I hit ‘ignore’ and ‘continue’
Hi @Kemolagger
After this print has been finished, could you reboot the printer and check what it says the tank is programmed to?
Seems it corrected itself after the print. Should be good to go now, thanks!
