Support dots
Just my form 2 few days back
After removing the support The support dots are like so big in white popping out, I did clip them one by one at the edge gently, Anything wrong I’m doing
What size are you setting them in PreForm? I use .35mm size but I also print rather small pieces.
the point dot i think the default 0.60
Mine defaults to .70, Usually reduce it to .60 for a part approx 3.5 inches x 2 x .5
However my last print in V3 White failed due to support failure.
When it failed does your resin spill out from tank?
always a possibility, however mine did not completely fail to the point it fell into the tank. Just ripped half the supports off and then warped badly. Also after any failure it is important to filter the resin for small pieces.
