Sunsetting notice: Temporary CB Resin V1, Permanent Crown Resin V1, Castable Wax 40 Resin V1, Tough 2000 Resin V1.1 and Durable Resin V2
Hi everybody!
We’d like to inform you that Formlabs Temporary CB Resin V1, Permanent Crown Resin V1 and Castable Wax 40 Resin V1 will no longer be available for direct purchase beginning on Sunday, March 1, 2026. (These resin formulations are compatible with Form 3 generation printers.)
Tough 2000 Resin V1.1 and Durable Resin V2.1 will no longer be available for direct purchase beginning on Sunday, May 31, 2026. (These resin formulations are compatible with Form 4 generation printers.)
Here is more information on replacement options and printer compatibility:
Material to be replaced Compatible printer Replacement material Description Compatible with Application guide
Temporary CB Resin V1 Form 3B BEGO™ VarseoSmile® TriniQ® Resin V1 Versatile ceramic-filled biocompatible material for temporary and permanent single units, bridges, and denture teeth. Form 4B Link
Premium Teeth Resin V1 Biocompatible 3D printing material for highly accurate denture teeth for digital dentures and temporary restorations. F3B/3B+, Form 3BL, F4B, Form 4BL Link
Permanent Crown Resin V1 Form 3B BEGO™ VarseoSmile® TriniQ® Resin V1 Versatile ceramic-filled biocompatible material for temporary and permanent single units, bridges, and denture teeth. Form 4B Link
Castable Wax 40 Resin V1 Form 3/3+, Form 3B/3B+ True Cast Resin V1 Wax-filled 3D printing material, designed for precision casting of intricate jewelry and complex engineering components up to 5 mm. Form 4, Form 4B Link
Castable Wax Resin V1 20% wax-filled material for casting that can capture intricate features and offers a smooth surface finish for accurate castings. All Form 3 and Form 4 generation printers Link
Tough 2000 Resin V1.1 All Form 4 generation printers Tough 2000 Resin V2 ABS-like tough resin for 3D printing, that offers high strength and stiffness, as well as high temperature, and creep resistance. All Form 4 generation printers Link
Durable Resin V2.1 All Form 4 generation printers Tough 1000 Resin V1 Ductile, impact-resistant 3D printing material with comparable strength, stiffness, and toughness to HDPE. Form 4, Form 4B, eventually Form 4L, Form 4BL based on print settings roadmap Link
If you use Permanent Crown Resin V1, we highly recommend that you upgrade to Form 4B to continue using BEGO™ VarseoSmile® TriniQ® Resin.
For questions about these materials or if this transition presents any particular issues for your workflow, please let us know and we’d be happy to connect you with the right resources.
This topic was automatically closed 180 days after the last reply. New replies are no longer allowed.
