Some problems
Hi, we are working with three similar materials. One works fine, the others are producing error 217. Any suggestions to circumvent this obstacle?
Thanks in advance
Hi! To be able to look into this, could you please specify with which material you are getting this error?
Hi,
We use your standard PA12 with a small amount of additional TiO2 .
It can be many causes, specially since you are dealing with mixtures here. Much more data will be needed to sort it out.
@R2D2 That error means the camera is seeing something too “bright,” which could be due to the mixture. I’d start with the support site about this error, and then open a support case if you don’t get it resolved.
