Simple prints failing
Hi, I have printed the same design a few times and needed to print at bigger scale, so I loaded up the build platform and every since piece failed. Has anyone had issues with overhangs when there is a loaded build platform? The nacelle of the wind turbine piece is meant to be smooth all the way around. It is a relatively new tank.
Mind you I only have experience working with Form 3 but if I were to print this I would position my parts further apart. I’d say at least 3 times between narrowest points.
I once loaded platform with 18 tightly packed pieces and they all failed. After cutting by half I’ve got them all nicely printed. No idea why but that’s Form 3 for you…
