Hi!
Do you have problems making silicone moulds from grey v3 resin?
My molds sometimes have surface irregularities caused by the silicone non solidifying properly.
My cleaning cycle is a 15 min IPA bath after print > 1 to 2 hours of UV curing > scrub the part with a soft brush and new IPA.
Anyone knows if this is the best cleaning or if the resin has any chemical that inhibits the silicone from catalysing?
I already let the parts dry for a day or more and blow compressed air on them before making the mold for cleaning.
I can’t seal or apply any other layer on top of the part because it would make the part loss detail and my molds are usually for very detailed jewelry.
For small parts contraction might not be all that bad.
The Formlabs material takes quite a bit to get cured properly. You must post cure under UV or the sun and do some extra cure from what is normal. If it’s only cured on the surface some of the green resin or IPA that is under the surface can weep out and cause issues.
I do it all the time. DO what you are doing but also coat the parts with a release agent. I use a teaspoon of Vaseline in about 3 ounces of mineral spirits. Just paint a light coat on the parts, sometimes two coats.
Bingo! That’s the problem, platinum is great stuff, but is inhibited by everything, the glues in most tapes, latex, sometimes CA glue. you can try to paint them with a thin coat of a paint that it will cure against - I have always hated working with platinum rubber for that reason, tin is very forgiving!
As well as hitting it with lacquer, for platinum silicone, which is extremely sensitive to contaminants, I’d suggest a couple of coats of Inhibit-X: https://www.smooth-on.com/products/inhibit-x/ It’s specially formulated to discourage that non-cure response that makes platinum-cure silicone so difficult to work with.
I don’t advise using thick primers, or (especially) petroleum jelly, which will obscure the fine detail you’re going through all this trouble to replicate.
