Show how the support will be created, not just a dot
Call it ocd if you want but I want to see how the supports will be created, like it is right now it’s nearly impossible to create identical supports on tiny models like in the picture.
Why can’t PreForm show me the support or if that’s for some reason impossible, at least let me select a support and micro adjust it’s position with the arrows on the keyboard.
Hi @Reine,
Thanks for the feedback! After doing some quick testing, it looks like the support previews appear for internal supports, but not for supports going down to the build platform. I’ll go ahead and submit your feedback on this as well as on adjusting the position of individual touchpoints.
If you want very fine control over your supports I’d suggest Chitubox and export the model back into Preform and print from there. That’s what I do occasionally.
