Please see attached for a saved copy of my most recent print settings, the STL for the part I’m trying to print, and some photos of the finished results.
Have you tried downgrading the firmware back to 1.7.6 (if your attempt to update it will downgrade)? Apparently the last two firmware updates for the 3L were pulled back due to issues but no idea if that’s related or not.
My 3L printer downdated itself today, removing the December firmware and going back to October, I will print some standard items today and let you know, if that works.
The firmware downgrade also worked on my machine, so that seems to be the biggest culprit. Thank you to @Eks and @Nicoyalife for pointing me in the right direction.
Because I had so many failed prints lately, I also played it safe on Friday and completely filtered the resin in the tank, checked the tank for any remaining solid bits I might have missed before, and checked the tank for any scratches or tears. Everything looked good, so I felt comfortable proceeding with the firmware downgrade and am happy that it payed off over the weekend.
