It’s the standard grey and black resins. Yeah was thinking of some sort of enclosure to vent out the window. Shame you can’t buy them though will look at what other folks have done. Not even the garage rybu? I would have thought that’s the perfect place for it!
The cardboard box the printer came in, a few feet of 4" dryer vent hose, and a 4" in-line duct fan (both of which you can find at a local Home Depot) is all you need.
Yeah thats a good idea, though the space I have for the printer is limited and doubt the box would fit. I think ideally it could even be a bin bag that velcros to a cardboard base the printer sits on with the vent hose and fan you mention.
Maybe a custom clear cover like this. just need to figure out a vent hose attachment.
Janky as it sounds, the cardboard box idea has merit.
I run two printers in a closet with a door that has gaps at the top, bottom and sides. Not even close to airtight. I installed a HEPA-filter air purifier inside. When I print, I run the purifier on high and use a towel to block off the gap along the floor. It’s not perfect, but it helps substantially. Anecdotally I’d say it reduces what I can smell outside the closet by about 90%.
My partner always used to complain when I was printing, now she finds it quite tolerable. Also helped win her over to the machines once we found items she was interested in printing herself and taught her how to use the equipment.
Here are some more professional-looking examples of what others have done:
These are great setups! Though looking for a solution for minimal space. I have a zvat cover I can enclose it in. Would that trap the fumes? Otherwise might try to make a zip up clear vinyl enclosure cover with a venting hose attached and out the window as the printer will be next to the window. I got a makeshift aircon cover I made from a shower curtain to attach to the window via velcro I can use for the hose. If the vinyl cover company can make what I’m thinking this should work. I’ll see if I can post a diagram here
I suspect any of those will help, just make sure there’s a fan or something to create airflow and suck out the fumes, otherwise they’ll likely just permeate to the rest of the room with little benefit from the cover. Also keep in mind if the material making up the cover is too thin it may just suck in toward the printer unless you do some kind of wireframe to hold its shape. Experiment and let us know what you come up with!
ah yes good point. I’m looking intot he custom pvc cover, hopefully it has a good amount of thickness. I’ll update the thread if I can get a good solution going.
After destroying my lungs by not using masks when I should have, I now live by the saying, “If you can smell it, you are breathing it.” I would not even consider using any Form printer (especially a Form 3) in a closed space without proper ventilation.
I have many Form printers and the Form 2’s tend to put off less fumes because they use a contact heater instead of a blow dryer in the Form 3. Even with room ventilation (1,300 cfm in a 10x12 space), when people enter my printing shop room they almost always comment on the resin smell. I print with std materials like Grey and Clear, as well as Durable and Tough resins. The latter do tend to smell more but that is a relative and subjective assessment. For reference, I personally find Tough 2K and 1500 unbearable with no ventilation and using the Form 3’s.
If your wife already has breathing problems - be safe and ventilate or find another space.
microdev: yeah that’s what I’m worried about. My son sometimes comes into the room and this thing printing for 7 hours is daunting. I’m trying to think of the easiest venting solution as I really don’t have the time or space to be custom making anything fancy. I’m really surprised no one has brought out a commercial solution given the number of form printers sold.
What do people think about this? encasing the printer in a zip up clothing bag and placing the extractor tube at the top of the zip? The hole for the hanger would need to be closed up and there would need to be a sealed hole for the power lead.
Additionally can also insert a pvc pipe connector structure inside of this to prevent collapsed suction and retain space so the fume particles aren’t trapped.
Nice idea, simple and effective. If I had the space I would make one like this. I saw this great design by volpin props. Could probably be put away in the cupboard when not used still inside the enclosure. Not sure where the exhaust would go if one was added.
I agree with Kenyi, you need to vent the fumes. Any bag or box will simply leak. If you have a window nearby, you can make something like a home built paint booth, or use a commercial one like this:
Put the printer right in front of it, and vent to the great outdoors.
Definitely. Temperatures swing pretty rapidly in the garage, so you have to do something to stabilize the temperature a little.
If you don’t do something to stabilize the temperature you get expansion/contraction effects in the print due to the material expanding or contracting due to the temperature change.
I’ll eventually build a fume hood for my printer, but for now I have a small heater that I put under the printer during the night.
Digital deck covers makes a cover for both the form 2 and 3, I had/have both and they work great.
I was in the process of designing some parts to attach a hose to the cover plus a small fume extractor. That really should be enough to pull all the smells out and then it’ll depend on how good of a fume extractor one is running. I have a well ventilated space now so I didn’t need to do that.
My space can also get quite cold. I haven’t noticed any significant issues caused by temperature. The internal heater tries to keep everything at a set point and it seems to hold fairly well.
