Absolutely, we have a recommended burnout schedule here and also recommend a specific investment. R&R Plasticast with BANDUST. I have heard that dental investments can work too but typically these are more expensive. You should ask your investment supplier for an investment that will work well with a photopolymer.
We screen casting houses before adding them to this list by ensuring they can work well with our resin specifically and produce good results. The burnout of photopolymers is very different to a wax burnout and it will often require a significant change to your casting process to achieve good results. The investment is also very critical, it needs to have a similar thermal expansion to the photopolymer and good strength at the point where the photopolymer is expanding most.
