I’m usually pretty tolerant of problems that come up in technology. I don’t default to blaming the gear.
But I’m being tested.
My first 1+ died within days. Formlabs replaced it, with an advance swap. Nice!
All was good, prints worked, and I gradually worked up to larger and larger prints over two months. Until I ran a print that maxed out the size. Failed. Thought it was me. Changed orientation. Failed. Changed base height. Failed. New tray. Failed. New Bottle. Failed. And the base was always welded to the the aluminum. It took a chisel to pry the failed models off.
Support suggested I clean the galvos. Cracked the case and the galvos looked clean. But the 45 degree mirror below was filthy. Smudges, finger prints, hairline scratches and a small chip in the bottom edge. Since I had never opened up the base, I’m confident it shipped this way.
I cleaned the mirror, and magically, I’m printing again.
When I reported this, support replied “Is there anything else I can do for you?”
Well, yes, yes indeed there is. First, apologize. Second, tell me what you’re doing to investigate and correct this lacunae in QC. Third, I blew through two tanks, and a couple of liters of resin.
How about comping me some consumables? Ordinarily, I’d consider failed prints a part of the cost of doing business. But given how yucky the mirror was, I’ve reconsidered. I’m not after my time, just the wasted materials.
Their error, their responsibility.
I’ve seen a number of posts that might fall into the “poor QC” bucket. I haven’t seen any movement towards “make good” consumables.
Has anyone succeeded? Should we press for same? On one hand, I want Formlabs to be healthy. On the other hand, if poor QC becomes costlier, maybe they’ll be forced to address it more aggressively.
How do others feel?
