Post processing used on Clear resin sample part
Hi. I am beginning to experiment with finishing clear resins. I got the this sample part and I can’t see where it notes how the top layer was finished. There are clearly supports used here that were removed, but then something else had to be done to get the very glossy finish on top of that.
Does anyone know what process was used? It does not look sprayed or dipped and I doubt they would be polishing this. Thanks for your insights. My results of spraying and polishing arn’t going so great so far :(.
Here’s a picture that kind of captures the top gloss finish.
Sample part:
I dont know the process they use but we will sand from 80 up to 800 grit and we will use a polish and it takes quite a bit of time here is a example:
I know we will sometime spray Acrylic Clear Coat on Parts as well.
Hey! I’ve made a few clear resin projects for socials over the years:
Kitchen glass replica
Snow Globe
Putting a Benchy in a Bottle
For clear parts, I do a two-stage buffing and polishing process using a polishing lathe, first a wet cutting/buffing step with a pumice substitute, then a dry polish with a tan high-shine bar. After that, I either apply a clear coat or wipe it down with mineral oil, depending on the final look I’m going for. Mineral oil is great for making parts look good in photos, but it dries up over time, so for a more permanent finish, I’ve tried a million different ways. For large flat pieces, I use a palm sander, going from 100 to around 800-1000 grit to smooth out surface artifacts, then either buff the outside with cutting compound and a car buffing wheel or apply a self-leveling clear coat. For small parts, I use a rotary tool with scotch brite abrasive and polishing bits. You can play around with different compounds, I’ve had good luck with the dental workflow of pumice substitute and tan high shine compound, but I’ve also experimented with the 3-step Novus acrylic polishing system, as well as Meguiar’s car compounds for cutting, buffing, and polishing, and have had great results.
For the photo of the microfluidics sample part, that part’s top surface is naturally glossy from the tank’s film, so there is no polishing done, just flushing out the channels and curing. You could get it clearer on all the faces with the standard 2-stage polishing process outlined above on a polishing lathe. It’s relatively quick and easy, but you can achieve higher levels of clarity with other methods as well, like @MattRForerunner mentioned.
Another trick is using UV-cured clear resin (not for 3D printing), rubbing it into the surface, and curing it under UV light, kind of like mineral oil but without the residue. It really depends on what the part geometry is and what level of clarity you’re going for. I’ve experimented with so many different processes that there isn’t one singular one, but that’s the general path I go down.
In terms of preventing yellowing from ambient UV over time, you can kill two birds with one stone by spraying a clear printed part with a UV resistant spray clear coat. I’ve found most cheap ones work well, but automotive ones are a little more expensive and are better with a smooth glossy self-leveling finish.
For non-engineering (purely aesthetic parts): An important note that I would like to emphasize when I saw people trying to recreate ones like the bottle, when you export your model, make sure you really increase the polygon count when exporting. Seeing facets really kills the magic. The way I got this bottle to look so realistic, is I exported the perfectly revolved bottle from Fusion into ZBrush, dynameshed it to 3M+ points, and sculpted in a lot of imperfections and “wobbliness”, to replicate how blow molded bottles are not perfectly consistent in thickness all around, and have slight warping and defects. A perfect CAD model will not have the same effect. Good luck!
@henryqiu @MattRForerunnerThanks for he thorough and comprehensive reply! Ive received all pieces to try and do all of the methods listed. I’ve printed some test flat coupons to get started. Using clear resin 4.1 on form3. Looking forward to upgrading eventually to form4.
I got some "polishing wheels that go on a dremel and first thing I found is that I have to drop the rpm to min which says 2k rpm and it still begin to mark the part. With the dremel it seems I have to use the “cloth” type or softy “puffy” type of wheels to avoid marking the part. The more solid material wheels eat right into the part. Do you use the buffing compounds on the more solid type of wheel like these 100PCS Polishing Buffing Wheel for Dremel Polishing Kit, Polishing Wheel for Dremel Tool Accessories, with 1/8" Shank for Dremel Buffing Wheels - Amazon.com? Or on the softer cloth?
I see the dental polishing lathes are pretty expensive. Do they have RPM contol? What other benefits do they have other than fixed wheel? Wondering if it’s worth the expense.
I did some sanding as described and clear coat spry and dip on some flat coupons. We are trying to image through these parts. Here are some initial pictures. Not bad! I’m going to move onto some non-flat shapes via polishing compounds.
Thanks for the feedback!
You definitely can, but you’ll want to use some fine Scotch-Brite rotary tool bits first to remove surface imperfections like layer lines or inconsistencies. The more stages you add in, like with wet sanding pads, the better your final surface will be.
Depends on the lathe, but usually yes. Ours has a fast and slow setting, and the slower one typically works better for polishing to avoid burning the surfaces.
It’s easier to apply even pressure at a consistent angle across a larger surface area. I mostly use Dremel bits for tight internal features that the polishing lathe can’t reach. For big, flat areas, automotive sanding and buffing tools also work well. I’ve experimented with lots of different tools and compounds and there are many ways to get very good results, there isn’t one that sticks out above the others by a ton.
I’ve also heard of people using different stages of rock tumbling media in a rock tumbler to polish parts with intricate geometries. It’s great for getting into small nooks and crannies that handheld tools can’t reach.
Your photos look great! A light wipe with mineral oil or clear coat can help enhance the finish if you want to cut some small corners in the final polishing steps.
We’re trying to replicate the surface finish on these samples with our Clear v5 prints. Do you have any links to the specific buffing compounds you used for the two-stage polishing process? Specifically the high-shine compound.
Thanks!
We use Protech Hi Shine bar for our dental lathe but I’ve personally used tons of whatever is available and they all seem to work relatively well.
I
