Orangenhaut / orange peel Fuse1+
Seit längerem haben wir das Problem das Orangenhaut an den Teilen auftritt (siehe Bilder). Wir stehen mit dem Support auch seit dem in Kontakt, leider ohne Ergebnis. Nun wäre meine Frag wer diese Problem auch schon hatte und woran es lag oder liegen könnte. Ich bin sehr Dankbar für jede Information zu dem Problem.
For a long time we have had the problem of orange peel appearing on the parts (see pictures). We have been in contact with support since then, unfortunately without results. Now my question would be who has had this problem and what it was or could be. I am very grateful for any information about the problem.
Wir haben schon das Pulver komplett getauscht, alle Komponenten richtig gereinigt und die Türe neu eingestellt. All das hat nichts gebracht.
We have already completely replaced the powder, cleaned all components properly and readjusted the door. None of that helped.
Unfortunately, I don’t have any information on a solution, but I’ve been dealing with orange peel recently. The problem started in early December but did not coincide with a firmware release. The poor finish I’m seeing is not as severe as your examples but is still significant. At the same time, I was getting severe pitting and as a result tuned the bed temperature down 1.5C. This mostly fixed the pitting issue, but the orange peel was still present.
The best guess I have for my problem is degraded powder, but this conflicts with your experience. I think some more information could help others to provide relevant advice.
  • How long have you had this issue, and does it occur on every print?
  • Are all the parts in the chamber affected or only some?
  • Are you printing in Nylon 12?
  • Have you tuned your bed temperature at all?
I am in the same boat and would be grateful to hear other’s experiences and potential solutions.
(Printing Nylon 12 @ 30% refresh, last two prints @ 50% refresh. -1.5C offset.)
The bed temperature was lowered by -2°C because the powder cake otherwise adheres too firmly to the part. We are printing with Nylon 12 GF, and all parts in the chamber are affected. The orange peel always occurs towards the door and hopper. The problem has been present since around October/November.
(Printing Nylon 12 GF @ 50% refresh -2°C)
A few questions. Are u printing Nylon 12 or Nylon 12GF?
Have you made any changes to bedtemp at all?
Is your printer connected to a UPS or a lineconditioner?
Some countries suffer from bad electricity.
We had the same issue on our Fuse1+ and that was the result of it not being on a UPS/Lineconditioner.
Try increasing the print armor in the print editor by 15%, that fixed my problem with the exact same issue. it will make the parts harder to clean but it absolutely works.
what do you mean by print armore?
Please show me where in Preform you can enhance armor. A screenshot will do fine.
(attachments)
Where in Preform do you find these settings? Is it some developer version you are using? I cannot it in the latest version.
I found the settings. :smiley: Thanks
I don’t know if this will solve your problem, but I also had problems with orange peel. It was solved with several options. The first cause was already very over-burned and used powder, so you need to increase the amount of virgin powder to 50/70 or 100%. From our observation, stale powder is harder to bake and higher temperatures are needed. We tried to test for some time what would happen if I didn’t use virgin powder at all and we printed only 100% used powder. Orange peel appeared almost always. The only thing we could adjust was the bed temperature, when the print was successful only after increasing the temperature in the chamber by +3 or more degrees. Unfortunately, then it is very difficult to remove the unbaked powder around because it sticks very much to the part, but it is still possible. The unbaked powder is also destroyed even more. Due to the increased temperature, the tolerance of the parts also changed. This was really not a uniform solution. However, it corresponded to our research. This also corresponds to the fact that orange peel occurs closer to the door where the temperature is lower than in the back of the chamber where the heater is located.
Simply put, you can also see it when printing. Orange peel is essentially an analogue of warping in FDM. You can see how the edges of the layer are sintering. That is why this only happens on the bottom layers, not the top ones.
The solution is therefore to increase the temperature - either the chamber or the protective layer or use much more virgin powder. It also helps if you rotate the parts so that their bottom layers are towards the back of the chamber or as close to the center as possible.
The problem is simply constant temperature. We printed in places where we knew that orange peel would appear, just like with FDM printing, in order to locally increase the temperature there.
I had orange peel once, PA12 30% refresh but I usually run a higher refresh due to low used powder. Support suggested keeping parts away from the edges and upping the refresh a bit. Haven’t seen it since and I do sometimes have models up against the wall. If you keep refresh in the 30-35% range, used powder is sintered into the models within 3 print cycles on average if your packing volume is close to matching the refresh rate. If you have a low packing density I can see where used powder would get used over and over and not get sintered.
Das ist ein ausgezeichneter Tipp, den werde ich auf jeden Fall ausprobieren. Darf ich fragen, warum der Wert bei dir so hoch ist? Bei uns war 2100 mW eingestellt, während er bei dir bei 8926 mW liegt?
That’s a great tip, I will definitely try that. May I ask why your value is so high? We had 2100 mW set, but yours is 8926 mW?
The increase in Armor Laser Power by 15% has indeed brought a significant improvement. But what else can be done now to achieve a finer surface?
The surface no longer has an orange peel effect and is significantly better than before, but it’s still not as fine as it was when it was new.
Virgin powder will always have a better surface quality than used powder. You must use brand new powder or a very high refresh value.
For the first jobs with the increased laser power, the powder was completely new. We mix the powder 50/50, and the result is still better than before, but nowhere near as good as it was when the printers were new.
A small update from my side: We also had to deal with a few light spots on the outer surface of a few parts. While we really only had to sort out a handful of parts, we also noticed a slightly rougher surface on the parts in general. We still had sample prints left over from the very first print jobs and compared the surfaces here.
We tried a few print jobs with the increased laser output for the surface armor. Even though this eliminated the noticeable areas, the surface still felt slightly rougher than I wanted.
It was also a little more difficult to clean. As many of our parts have holes and drill holes, the cleaning effort was significantly higher.
We had previously calibrated our Fuse to -1.5°C in order to print the upper areas of printed parts more smoothly and avoid the “burnt” effect.
Therefore, instead of increasing the laser power for the surface armor, we have now increased the offset back to -1.0°C. In this way, the surface armor is also supplied with more energy again.
So far it has made a very good impression. We no longer have any problems with bad spots and cleaning is going normally again.
We had the temperature set to -1.5°C at times and have since returned it to 0°C. We also mostly have parts with holes and blind holes, and the cleaning effort is significantly higher compared to the lower print chamber temperature, but the surface no longer has orange peel texture. However, when I compare the surface to the patterns from the first prints, the parts are generally lighter and have a rougher surface. Initially, the surface was really smooth, and the part was almost black. (See picture)
I’ve had one of my Fuse1 printers in use for about 2 years and have not noticed a difference in surface texture.
