Just some updates on testing.
Now that I have been working out the faulty chamber issue with Formlabs causing all the failures, I have run a few chambers with these settings now in Default and even though they help reduce the burr… they are still there even ever so slightly.
Add to that, I tried running the Speed Optimized settings again with these adjustments and the parts were too “crumbly” along the edges and the burr was still terrible.
Also, the “bar code” line issue showed up again. This is similar to the X/Y calibration lines and bar codes I pointed out to Formlabs. (shown here on every Speed Optimized Setting test print)
They supposedly fixed this last week as they found an issue with what they said was something to do with layers getting printed out of order or something like that… but as you can see this artificial line is still there on my parts and they told me that this was probably from that issue.
See photos of the bad burr and crumbly edges and pointing to this artificial barcode/line protruding into the part along an edge.
My gut is telling me this is a software/slicing issue and nothing to do with wrapping or edge orientation, as I see this happen on every edge in any orientation, just in these two new Default and Speed Optimization settings.
Due to this, I was recommended to run in Legacy settings, as I see none of this happening in that setting on these same part jobs.
As I said before, I think these new settings were focusing on better “part accuracy and detail” which in turn means sharper corners hence these increased edge issues I am seeing. To me I would prefer sharp corners to have a more “sanded finished” look to them as I see in Legacy mode… but maybe something for you to consider on your own parts.
I know this is not just something happening on my printer… as I even see it on all the Formlabs sample parts that I received in the past week.
Something else you/we could do… is add a chamfer or facet to all the hard edges in the CAD design of each part… but right now I am not seeing much benefit of doing all that for Default settings versus just running Legacy and Speed Optimization is even worse for just an hour or two shorter speed per chamber…
In the future it would be cool if Formlabs combined all the settings it took…to “handle corners”. For instance if you prefer sharper or a more finished edge on your prints
