Hey Everyone,
I’ve had the Form1+ for a little over a month now and have had about 85% success with the various prints I’ve tried. The only failures I ran into were my very first few prints that were not attaching to the build platform properly. This was quickly solved by changing the fine tuning settings. I am now working on printing a sample of an object that I want to ideally print 20 times or so. It is a simple 55mm x 55mm x 3mm plate with several dots on top that represent braille dots. The first test print with this model had several bubbles in the upper surface, and the dots were not the proper height.
I am unsure if the printing error is something based around my actual design and the .stl file, or something with the scaling in Preform. The .stl file of the plate is exactly 10 times smaller when imported into Preform. After scaling it up by 10, it displays the proper x,y, and z dimensions, but after printing the height was not correct.
I am hoping I can have some members here take a look at my design files and give me any feedback regarding the design and orientation in Preform.
I am also wondering if supports are really necessary for an object like this. The supports increase the resin needed by more than double, it increases print time, and leaves a very sloppy/partially cured underside to the plate. I will test printing without the supports soon, I am just wondering what everyone’s opinions are on supports and there necessity with a design like this.
Any information would be greatly appreciated!
