Hi, I’m looking for information regarding the densities of the materials, specifically Tough V5. I was able to find a datasheet for the V3 which states the density is 1.09 to 1.12 g/cm3 (not sure if the units are correct but I saw other datasheets use it). I was wondering if it’s the same for the V5 material as it does not state it in the most recent datasheet? Thank you
Hi @czarsimon, it sounds like you grabbed this data from a materials safety data sheet for the liquid resin. Are you actually interested in the density of the solid cured resin? I asked someone from our materials team if they can weigh in here
Hi @arusso yes I’m after the density of the solid cured material, I appreciate your help
