Is it possible to make more liquid ordinary gray rubber with isopropyl alcohol?Since in the tank it evaporates and becomes thick
Liquid ordinary gray rubber with isopropyl alcohol
sharpknlfe
#5
Probably not. I am not sure if the laser may even trigger the flash point of IPA. Tinkering with the resin mixture will throw off what the laser was programmed to do.
