Had my first print fail been using the Form3 for a couple weeks on small objects no problem. I am looking for some advice on how to print a large object in terms of generating the right support density and touch point size for something of this scale. Settings for this print was density 1.0 and 0.6mm touchpoint size.
Any advice most welcome on printing large objects and supporting them correctly.
It fell off the supports. The settings were density 0.8 and touch point size 0.3. I think these may have been too low as we had success with smaller models at these settings.
I had the same problem with a figure I printed.I used similar touchpoint size and parts broke off.When I reprinted I used the touchpoint size of 0.6 and it worked fine
Oddly, I have had success going the other way - touchpoints of .4 and a density of .7. So fewer of them, but larger. And most of my prints are on the large size. I make enclosures for my electronic products - so big boxes.
Hi nsayer, do you have any images you could share of the type of enclosures you are doing, this is where my interest is but i am very new to this and would appreciate any advice that’s out there
Thanks again, my name is Bill. I had a look at your files on thingiverse and i was hoping you might be able to share some screen shots or even better a form file of the GPS Clock case print? this file is pretty similar to the type of items i would print with the biggest aim to avoid warp and nasty contact marks everywhere. I don’t think it will be for production but more for proto-types. I hope i’m not imposing just keen to pick up knowledge about the process.
