How to set the off set X and Y axis Values on LPU alignment LAP test on form3L
Hello,
I have changed my Form3L LPU ( did the print test for laser alignment LAP)- now i have to set the values from the lap test results. Please if someone did the same, how you checked them?
thank you
Hi @Mim,
Sorry for the late response but wanted to make sure you were able to get this done. If you haven’t already reached out to our Support Team, I would advise you do so; they can get you the guide on how to run the calibration and answer any questions you might have about the process.
Hello Corey,
Could you please send me a replacement LPU? I would like to get this machine up and running again.
Thank you!
Non-Sensitive
Hi @andrewcwood,
Our Support team will be able to send you a replacement LPU if necessary. Please reach out to them in order to sort this out as efficiently as possible.
