I’ve got a really complex geometry (see attached screenshot), and no matter what orientation I put it in, it seems to suffer from insufficient support. PreForm indicates this through “red” areas … from what I’ve read in docs, the more dense and darker the red, the more the print is likely to fail … however, it is somewhat challenging trying to figure out what is/will likely be a catastrophic failure on the Form1 … any way to give a percentage of failure in the software? maybe in the problematic areas, or perhaps something as simple as a text area in the UI someplace? … a more challenging feature would be to show, using a basic physics engine … what is likely to happen in PreForm during the layer by layer animation …
Is it possible to build into Preform, a feature such that an operator hits a button and it cranks through a bunch of orientations and support structures until it finds something that “works”. Maybe it gives “scenarios” on which an operator might pick? Would require building some further intelligence into the Preform platform.
Does Formlabs need a really good test model for internal use for testing support mechanism? The attached might be a good one to test new features with.
I am likely going to split up the .stl into multiple parts, print separately, and then reassemble. Seems like an avenue that might work.
Just ideas.
