Help with model failing to print
No problem. Hope it turns out great. If not, then I think you should try the hollow version again.
Hi Monger,
Thanks again for sending me that file. I tried the print with the STL you gave me, it failed pretty quickly unfortunately. Not quite sure what is going on with this particular head sculpt. All seems okay with the stl and I tried to use my other tray with clear resin, which has been printing successfully with my other prints to print this bust and it failed to print past the supports. I might try printing something else that I have successfully printed before to make sure that the printer is still calibrated correctly.
Sorry to hear it failed. You should really have them check your machine. Your laser may be misaligned. Have you checked the main mirror for dust or spilled resin?
