HI there.
My grey V4 resin is almost gone and I have a new white V4 resin and I was wondering if could change the cartridge so both resin would combine in the tank. I don’t want to clean the tank before changing to white or use the remaining grey in open mode.
If there’s just a bit of the grey resin residue in the tank then it probably won’t affect it very much, you’d just need to make sure that once it fills with the white resin that you use the scraper and stir the resin well before printing.
If it’s more than just some residue, then don’t mix the two together, the grey will make the white resin take longer to cure and would make your prints more likely to fail.
