Greetings all, I’ve recently encountered a new part with relatively thin features (0.030") and the first test prints I’ve done have not turned out satisfactorily using the Beta 3.0 settings for Nylon 12. Primarily the parts being thinner than expected (0.025"-0.026") and what I’m interpreting as under-sintered cross sections. So I’ve started to play around with the print settings to see if that leads to better results, and my question concerns the Perimeter settings. The Beta 3.0 settings have the perimeter set to 0, and I’m wondering if I add a perimeter, does that actually add material to the nominal of the part?
Otherwise it’s hard to interpret with the slicer if the setting changes are actually doing anything. Is it possible to have the slicer show the different laser types making up the part (surface armor, perimeter, fill)? Screenshot attached:
