Flexible resin - water tight?
I need to print a tube which made of flexible material, and it needs to be water tight
how water tight is the flexible resin?
Hello!
Resin is in general water tight, as the layers are bonded chemically instead of mechanically. However, in time, resin may react to water.
You can find the data sheet here and the safety data sheet here
We have not done extensive tests in this regard though.
You can find our solvent tests here
Hope this helps!
Alina
Thank you Alina for the detailed response!
