When finishing a piece from the Form1 … is a cheap dust mask good enough protection when sanding resin based prints by hand with paper/block? I imagine so.
I presume one would wear a better protection when using something like a small handheld power dremel sander on larger areas of a print … like a half mask respirator.
I am under the impression that one should take precautions same as when sanding wood, as they would with resin … but I’m just wondering what level of protection that should be.
I’m going with #1 and #2 just to be safe depending on what is expelled from the work piece during any post process needed on prints due to support, any noticeable defects, result modifications, etc.
Thanks.
-sj
