F2 Missing Cartridge - Any fixes?
:exploding_head: We carefully insert the resin cartridge into the F2. We carefully clean both the chip on the machine & the chip on the resin cartridge. Sometimes, in order to connect the cartridge & machine, we need to wiggle, jiggle & shove things around.
What solutions have you found? Anyone or anything?
37%20PM
Some cartridges connect if they are lifted an inch or two and dropped into place, others prefer to be pushed slowly and firmly.
The “drop” method is a new one. I hope FL has some sort of official solution. Thanks!
If you haven’t already, please don’t hesitate to reach out to our services team and they’d be happy to take a look to make sure this isn’t a consistent issue for you!
How are you cleaning the chip in the machine? I had to put a cotton swap dipped in IPA on a long stick and shun a light down giving a few rubs as someone advised on here. fixed the issue straight away.
Hi Formbeast.
Thank you for commenting.
Im cleaning with the IPA & swab also, sadly to no avail. The failure is intermittent. I am very careful with storage, insert, removal and cleaning.
Frustrating.
I was very fond of the brand… but this brand is rubbish. Never respond, Form2 only gives me problems, with everyone I’ve talked to. Shame on this brand.
HOW TO FIX:. Put cardstock behind the contacts on the resin cartridge (needs pushed closer to the contacts in the Form2 to read that it is there
I cut cardstock, folded it over and double sided taped it behind the contacts. Fixed 2 tanks this way today.
