Enclosure size for Form 3 / 3+
the link is above - but i’ll let you know once we worked out the details
We took the measurements right from form labs …also because this does not open from the bottom the printer does need to come in and out through the front door …hence the reason for the size adjustment to making it a bit wider.
Got it, thanks!
I have good news… the design is being updating with a door to access the resin area
Great and responsive company
These guys rock!
Great, thanks for the update.
Much progress! - 3duplifters are great to work with…this is made for the Form 3 / 3+/3b/3b+ printers its tall enough to have the top open as well
There is a top hatch to load in the resin cartridge and the front door is big enough to load the printer in. This means all 6 sides are attached and air evacuation can happen at the back with a 4 inch hose adaptor. I’m planning on using a ACInfinity cloudline 4in inline fan with a ventworx window adaptor plate
Here is a video 3d mockup…!
https://share.icloud.com/photos/043Mcpf3ixCfyYGgYv9I_BsLw
Great! Where does the BOFA Print Pro connect to in this enclosure?
you can either use a bofa to suck out air out i to the filter …or send air out the window using a in-line fan like from AC infinity …there is a 4 in hole with adaptor at the back for duct hose setup… if you need a return hole ask them for a modification so you have two holes. …note we also put in a top door for the form 3/3+ resin cartridge loading.
You can see it better in this linked video
