Hello! we make large use of this resin, and I would like to know more about the mechanical properties of it.
For instance, I would need to know density, elastic modulus, Poisson ratio, Flexural modulus.
Thank you in advance.
Alessandro
Alessandro
Hi @beriols,
Thank you for getting in touch! Some properties are mentioned on the Elastic 50A Datasheet. Specifically for the elastic modulus, this would be approximately 1.5-2 MPa at 50% strain. Some mechanical properties are untested by us, such as Poisson’s Ratio, and you would need to perform tests yourself if desired.
