Elastic 50A V2 different orientations give different dimension
Hi everyone, I’m facing an issue with elastic 50A V2 resin. with the same part, when I place it in different orietations ( as in picture) then it turned out different thickness. The one up is more accurate than the lying one. Has anybody ever experienced that issue and how to resolve it? Thank you!
Hi @JuneJune84 ,
Thanks for letting us know about your issue! Orienting large, flat surfaces to an incline of 10–20º drastically increases the success rate. By printing a model at an angle, you are reducing the surface area of each layer while also decreasing the amount of contact the print has with the tank. Reducing the surface area means that the print is subject to less force as the build platform raises with every layer. That is why your model that is “lying” is not accurate/successful. Please check out our recommendations here.
