a) I was playing with the duplicate feature and see that the maximum quantity was 10. Is it possible to not limit the quantity?
b) I found out that after duplicating, several objects are fused together and it is difficult to locate where they are. Can you put a different color when object are fused together?
c) To move all the clones on the plate, I would see a feature “Ctrl” + select the objects to move them all at the same time instead of moving them one by one.
d) Finally, a shortcut to duplicate an object would be great. You can duplicate an object like you duplicate a folder/file in windows. In this way, you can quickly see how fast you fill your plate and it is easier to manage the room.
