Hi, all.
When I select a model in Preform I want to be able to select how many duplicates I need. I often need dozens and now I have to repeat the duplicate and that is axactly what software should do for me . Like every other slicer does. And no max please. Please FL can you do that? thanks, Maarten
Use the array function for that?
Thanks, I did not know about that function. In my line of thinking I first get all models on the plate, then I do the layout. Also, the array function is not in the menu. So… problem solved!
best regards, Maarten
