Was just about to go and purchase some clear resin, plus a tank for the form 3, but all I see is v2 resin tanks on the store.
What happened to v1, did they stop selling it and why?
V2 is a little expensive, especially if I’m going to be using it with resin that doesn’t even require it.
Hi Addio! Form 3 Resin Tank V2 is compatible with any materials that are compatible with the Form 3 and is priced the same as Form 3 Resin Tank V1. The only difference between the two is that Form 3 Resin Tank V1 is incompatible with Rigid, Grey Pro, Elastic, and Tough 2000 Resins. Resin Tank V2 has replaced V1 as the default resin tank for the Form 3 and Form 3B as of January 2020.
I didn’t realize the price of the tank changed from V1 to V2, is that correct?
It’s a $9 difference on shop3d…so not sure what op is on about…
Ah ok, for some reason I remember it being about $50 CAD cheaper.
