Denture Resin part bond to Heat cure denture
Can the Denture resin be bonded to regular Heat Cure denture material?
I have a metal framework obturator denture which I would like to bond a 3D part of the obturator to. Has anyone tried this?
Denture Resin has not been tested or approved for bonding with traditional acrylics, whether hot- or cold-curing. It will probably work, but this would constitute an off-label use for which we cannot assume responsibility.
That said, we have validated a third-party product—the Ivoclar Ivotion Bond Kit—for joining printed teeth to printed bases. This bonder is validated for use with our Denture Base Resin and, according to its IFU, is suitable for PMMA-to-PMMA or composite teeth. It may be an option worth considering.
Thanks I will give this a try.
