Requesting the ability to adjust the support diameter settings for the Form 3.
With the reduced force on the printed object the current strength of the preset supports is no longer required and with the fixed diameter setting provided with the inbuilt auto-generated support does not accomplish much except for using more resin.
I primarily print miniatures using my form 3 and anywhere I can reduce resin consumption will give me a added benefits in the long run.
