Copy paste the below info into notepad, save with extension .ini and load through OpenFL. This is for the Form1+ machines using ApplyLabWorks Black v2 resin.
d8888 888 888 888 888 888 888
d88888 888 888 888 888 o 888 888
d88P888 888 888 888 888 d8b 888 888
d88P 888 88888b. 88888b. 888 888 888 888 8888b. 88888b. 888 d888b 888 .d88b. 888d888 888 888
d88P 888 888 "88b 888 "88b 888 888 888 888 "88b 888 “88b 888d88888b888 d88"“88b 888P” 888 .88P
d88P 888 888 888 888 888 888 888 888 888 .d888888 888 888 88888P Y88888 888 888 888 888888K
d8888888888 888 d88P 888 d88P 888 Y88b 888 888 888 888 888 d88P 8888P Y8888 Y88…88P 888 888 “88b
d88P 888 88888P” 88888P” 888 "Y88888 88888888 “Y888888 88888P” 888P Y888 “Y88P” 888 888 888
888 888 888
888 888 Y8b d88P
888 888 “Y88P”
[perimeter]
basexyfeedrate = 400 ; Laser speed in mm/s for the perimeter of the base (aka raft). (Faster than 800 mm/s may noticably reduce surface quality.)
baselaserpowermw = 45 ; Laser power in mW used for the perimeter of the base (aka raft). (max: 62 mW for Form 1+)
modelxyfeedrate = 600 ; Laser speed in mm/s for the perimeter of the model. (Faster than 800 mm/s may noticably reduce surface quality.)
modellaserpowermw = 45 ; Laser power in mW for the perimeter of the model (max: 62 mW for Form 1+)
supportxyfeedrate = 600 ; Laser speed in mm/s for the perimeter of the supports. (Faster than 800 mm/s may noticably reduce surface quality.)
supportlaserpowermw = 45 ; Laser power in mW for the perimeter of thesupports. (max: 62 mW for Form 1+)
[PrintSettings]
SliceHeight = 0.05 ; The layer thickness in mm. For example 0.1 is 100 microns. Be aware that values not corresponding to whole z-motor microsteps (0.0025 mm) will be rounded.
ScanlineSpacing = 0.09 ; Spacing of fill lines in mm.
InnerBoundaryOffset = 0.12
OuterBoundaryOffset = 0.03 ; Offset from model perimeter to outermost outline in mm. Conceptually this is the curing radius of the outermost outline.
Xcorrectionfactor = 1.01 ; Scale factor for the x axis to account for shrinkage.
Ycorrectionfactor = 1.01 ; Scale factor for the y axis to account for shrinkage.
ScanlineBoundaryOffset = 0.03 ; Offset in mm from the innermost outline to the boundary of the fill. If this is zero, the fill touches the innermost outline; if this is positive it does not; if this is negative, the fill overlaps at least the inner outline.
OffsetsNum = 3 ; Number of outlines to draw. min: 0; max: unlimited
[Overview]
MaterialName = BKtest_0.05_0111_2
[laserRoutine]
firstlayerpasses = 10 ; The number of laser passes to do for layer 0 to attach to the build platform.
otherlayerpasses = 1 ; The number of laser passes to do for most layers (typically 1).
earlylayerpasses = 2 ; The number of laser passes to do for early layers as defined by earlytimesexpose.
[btwnLayerRoutine]
earlytimesexpose = 50 ; The number of layers that will be exposed earlylayerpasses times (excluding layer 0). That is, if earlytimesexpose is 3 and earlylayerpasses is 2, layer 0 will get firstlayerpasses passes, layer 1 and 2 will get 2 passes, and subsequent layers will get otherlayerpasses passes.
postlasercurewait = 1 ; Duration in seconds to wait from when the laser turns off until the motors start to move.
earlytimespeel = 22 ; The number of layers for which the p1 moves will be done. These are typically slower moves.
p1downvel = 1 ; Initial tilt speed in mm/s (at the tilt motor).
p1downmove = 10 ; Initial tilt distance in mm.
p1upvel = 4 ; Velocity of p1upmove in mm/s.
p1upmove = -10 ; Tilt up-move displacement in mm (should be negative).
p1upslowvel = 10 ; Velocity for p1upslowmove in mm/s.
p1upslowmove = -0.5 ; Additional up move in mm to overdrive into the hard stop. (Should be negative or zero.)
p2downvel = 1.5 ; Velocity of p2downmove in mm/s.
p2downmove = 7.5 ; After earlytimespeel, tilt distance in mm.
p2upvel = 10 ; Speed of p2upmove in mm/s.
p2upmove = -7.5 ; After earlytimespeel, un-tilt distance in mm. (should be negative.)
p2upslowvel = 10 ; Speed of p2upslowmove in mm/s.
p2upslowmove = -0.1 ; After earlytimespeel, overdrive distance into hard stop in mm. (Should be negative or zero.)
squishwaitmin_s = 0.25 ; Low end of the time in seconds we wait between finishing squishing and turning on the laser.
squishwaitmax_s = 2 ; High end of the time in seconds we wait between finishing squishing and turning on the laser.
[fill]
basexyfeedrate = 400 ; Laser speed in mm/s used for filling the base (aka raft). (Faster than about 1600 mm/s may produce noticable artifacts.)
baselaserpowermw = 45 ; Laser power in mW used for filling the base (aka raft). (max: 62 mW for Form 1+)
modelxyfeedrate = 750 ; Laser speed in mm/s used for filling the model. (Faster than about 1600 mm/s may produce noticable artifacts.)
modellaserpowermw = 45 ; Laser power in mW for the model. (max: 62 mW for Form 1+)
supportxyfeedrate = 750 ; Laser speed in mm/s used for filling supports. (Faster than about 1600 mm/s may produce noticable artifacts.)
supportlaserpowermw = 45 ; Laser power in mW for filling supports.
