Using Clear V4 Resin to make a print. The print needs to be connected onto a thin acrylic film (<1mm). So far have tried to use the resin + uv cure as a method to adhere them together, but having limited success. Does anyone know any other methods to connect two small pieces.
Hi @pviste,
You may have good results using a cyanoacrylate glue or an epoxy. Alternatively, if you need to maintain flexibility and elongation, a flexible urethane adhesive would be another option. If you’d like further guidance, please feel free to reach out to our Support Team.
