It would be helpful to be able to have the ability to delete previous jobs from the Dashboard.
Now, one has to do each one, one at a time, on the printer itself.
Kirk
Kirk
Why do you delete them ? Do you need to make sure that they do not get printed again ? Otherwise once the memory is full the older jobs get erased automatically.
Don’t know if they’re changed the behavior, but it was possible to not have enough storage space to perform a firmware update, necessitating deleting some previous jobs manually.
as with most computers they run faster with empty drives. so more files you load the slower it runs after a certain point. also older models may run better if you make new form file since they keep upgrading it.
Isn’t the memory allocated specifically for the jobs and have reserved space for system? If so then it shouldn’t matter and not effect performance as older jobs are removed as new ones loaded.
I know this is old post but this is still not an option and I think it would be great to have this capability
and if not though dashboard than at least as printer menu item, maybe by last week, month, year prints etc.
I for one really repeat a print job and with 3 form 3’s I print allot
thanks
Jarek
I also would like sometimes to deleta a job I have uploaded but changed my mind the last second. For now, I have to go to the printer and delete this job, and return to my computer to upload a new one. It would be nice to be able to do it from the dashboard.
Someone from Formlabs if you read me…
