So I saw the 3d printed lens project on the formlab page and figured I would give it a try.It worked very well.
I used clear resin at 50 micron resolution with my Form2 printer.
I chucked the lens in a drill and wet sanded with 220,400,600,1000,1500 and 2000 grit paper
I then removed the lens holder backing,put the lens in the second holder and sanded the flat side of the lens using the same sandpaper.
I polished the lens using a NOVUS polishing system
The finished lens was actually pretty good.With more careful sanding I could have made it better
(upload://3Pf9MNycGsfykRfC5wQO0m45JQc.jpg)
