Hi!
I couldn’t find anything about the maintenance of the threaded rod in the Form 2. So my question is the following: Is it necessary any lubricant/grease or something else for it’s maintenance?
What do you suggest?
Thanks!
Typically, maintenance isn’t required on the leadscrew. If you’re noticing bad sounds, Magnalube or Extreme Pressure Lube #3 will help.
Zoro synthetic multi-purpose grease (link) is also a winner.
Adding to what @CraigBroady said, if you’re having any issues with your lead screw lubrication and get in touch with our support team, we have small packets of Magnalube that we can send.
Thanks! Everything is fine now, I was just thinking that is better sometimes to grease the rod.
