Printer works fine few month ago but now it's not
an image will always explain it better
I run the formlab test and it works fine but not on big objects
Clean the large mirror, and possibly the galvo mirrors if that doesn’t help. On the Form 1/1+ you are pretty much guaranteed to get dust on the mirrors which will need to be cleaned off from time to time.
Thanks Zachary.
my main mirror is clean.
but I didn’t check the galvo.
my problem is quite similar as this one : Suddenly every print fails
Yep, almost the same problem. Except I’m using the Form 2. I really am starting to think this is because of a software (or firmware) update.
90% of the time it’s dust that’s the issue, if you look here: http://formlabs.com/support/printers/form-1/mirror-checking/
If you get a light in there you’ll probably see a lot more dust.
