Apparently I’m stupid when it comes to certain things because I can NEVER remember which of X, Y, Z Axis is which and the +/- direction on the PreForm Build Platform so most of the time, instead of using the 3 Tabs in the Alignment Window I use the 3D Object Manipulator to rotate stuff around BUT this one does ( apparently? ) not have an indicator how many degrees I’m rotating a part which most of the time is kinda a hassle for me.
I’d also like to see an option to have the ability to toggle between mirroring / rotating multiple objects as a group or independantly - Like when I create an array of 5x4 on the build platform and decided the group ( as if they were a single model ( should rather be facing a different direction ) then I can’t do that but instead they are individually being turned which, depending on how the layout was before, may now cause intersections where there were none before.
