Failed Print issue
It looks like you set it up quite well. It looks like resin is curing where it shouldn’t. as layer start to cure beyond the edge of the model they begin to become part of the model during pealing, as you see early in your print. But if the model has a thin area, such as your does near the end, the model becomes part of the layer on the bottom of the tank.
The first thing to do is clean the bottom of the tank and remove any chunks for the tank.
Then do a laser spot test as described here: Are your prints failing because your laser focus is degraded?
Take a picture for your records of the test result.
Either the mirrors are dirty or the laser is not focusing correctly. Check the main mirror carefully by shining a light from the bottom up and look for a haze. Take a picture of that too if you see it.
