Wash L and Formlabs Resin Wash
As of now, there is not preset profiles for in the Form Wash L for their in house Resin washing Solution. After contacting support, the only way to monitor the saturation level is to purchase a hydrometer on my own which I found a bit ridiculous. The main reason we bought their solution was to have the process streamlined from one manufacturer.
Maybe once the parts come out stick after a wash will be a good time to change it then you’ll just have to monitor it.
We just bought a Hydrometer for the specific density that is recommended, was about $30. And I just check it every week or so depending on the amount of prints we are doing.
That’s what they recommended to me as well. Working for the federal govt, its not quite as easy as “just buy this cheap thing”, especially this time of the year where the department budgets come into play. It would be months before I could even think about buying anything else.
At the end of the day, I just wish it was something they would have made clear to me before buying so I could have included it in the original purchase. Or I would have just bought off the shelf IPA as it seems they have a set profile and built in monitor for that. its just surprising to me that they don’t have that option for their own product.
You could use the supplied one that comes with the Form Wash possibly, just calibrate it with a tank of fresh wash solution?
The Form Wash L unfortunately doesn’t come with one.
The best visual indicator is to just keep an eye on it for a color change. it looses transparency with saturation.
Seems to me any competent manager could see their way to a $6 accessory to save $150 of IPA (assuming you can’t convince them to buy you a $150 still off of amazon and a heating element to recycle 80-90% of your IPA..
Thanks so much for reaching out, Chris, and for sharing your thoughts.
Our team is always striving to deliver the best possible experience, and your feedback is very valuable. We’ll be taking your input to heart as we plan future improvements and continue to evolve!
This isn’t a “nice to have”, it’s really a must-have. Considering that sensors and “sophistication” are a major selling point for the WashL it’s objectively reasonable to expect the system to monitor solvent health for Formlabs Resin Wash Solution.
Agreed. My point exactly.
Is this something that could be added in a firmware update to the Form Wash L? We have two of them set up and ready to use today for the first time. I was shocked to find out that there isn’t a profile setting for the Formlabs Resin Wash. Seems, well, shortsighted at the very least! Hoping a firmware update could add this profile.
Is the material close enough to simply use the TPM profile???
Yes, this would require a firmware update from Formlabs, I sure hope they are actively working on this or I wont be buying their wash in the future. Agreed that it is a little shocking as I bought their wash for the exact reason of hoping to be a little more streamlined then off the shelf IPA/TPM.
I have been using the TPM profile to just get by in the meantime but dont take the saturation levels displayed on the screen seriously.
Can someone from FormLabs quickly confirm or deny if this update is going to happen? I’m putting together a consumables order and if this update isn’t going to happen ill have to go with off the shelf IPA.
Hi Chris,
We do not have this on the roadmap at the moment, since implementing accurate solvent monitoring for Resin Washing Solution is extremely challenging with the current hardware. That’s why the use of a hydrometer like the one linked in our support article is the recommended solution.
You can still use Resin Washing Solution in the Form Wash L the same as you would IPA, but to monitor the saturation, you will have to rely on a hydrometer.
