Ultrasonic washing with Formlabs Washing Solution
Ultrasonic Cleaning with Formlabs Resin – Internal Thread Challenges
Has anyone here used an ultrasonic cleaner in combination with the Formlabs cleaning solution?
We’re printing parts with fine-pitch internal threads and consistently run into issues cleaning uncured resin from the V-groove geometry. This residual resin often causes interference when mating with external threads, which are comparatively easier to clean.
We’re considering ultrasonic cleaning to improve resin removal in these tight geometries. If you’ve tried this setup—or have alternative methods that work well for internal threads—I’d really appreciate your insights.
Thanks.
There are several posts on this specifically, and a search function to find them.
From what we researched, Simple Green exceeded our ultrasonic. heated or unheated.
Thanks for the reply. I did use the search but didn’t scroll down far enough to see the other responses, my bad.
We only have a Wash V1 which doesn’t do a very good job or removing resin from small internal threads (fine for all other prints though). Maybe the Wash V2 would be better in this regard? But the cost is prohibitive at $1400 and an ultrasonic washer is only a couple of hundred dollars.
I feel removing resin from threaded holes (smaller than M10) especially blind ones is a very specific case that requires a special workflow?
The wash solution cannot flow through or around the features so this is where I was hoping the ultrasonics might work.
Thanks.
The point there was to use SG to prep your part, as it helps remove more of the resin, which resolves much of the issue.
We have many threaded parts and tight tolerances, and we have NEVER brushed a single part in the post production.
I’ll get some SG and try it out. Is there a particular product in there range that you would recommend?
Thanks.
https://www.lowes.com/pd/Simple-Green-2-5-Gallon-Sassafras-Dilutable-All-Purpose-Cleaner/1000226631
simple green concentrate… ~$8/gallon at lowes
I use a spray flux solvent and compressed air when I need to clear small crevices. Just do the clean a couple times, spaying into the crevice and blowing it out.
@Andrew_W, we don’t have any formal documentation on using an ultrasonic system to clean your parts with the Formlabs cleaning solution. This article on Cleaning internal cavities and channels has the best collection of suggestions for getting those parts clean where you need them.
