Show build chamber / bed temperature in the remote camera view (Fuse 1+)
Hi everyone,
I run a Fuse 1+. I’ve set things up so I can view the printer’s local camera feed from a remote site over VPN. (Honestly, it’s hard to understand why this doesn’t already work remotely out of the box, but that’s a separate topic.)
What I’d really like is a way to check the bed temperature remotely as well. The printer already reports this data, so sending one more value alongside the camera feed shouldn’t be a big change.
My print farm is about an hour’s drive from where I am, which is considered fairly far here in Korea. When a print finishes in the early morning hours, I need to confirm the bed temperature before moving on to the next step. Right now the only way to do that is to be physically at the machine.
Having bed temperature visible remotely, either in the local web/camera interface or in Dashboard, would make a real difference for anyone running Fuse printers unattended or off-site.
Thanks for considering it.
This is reported in the dashboard if you select the printer
It really worked for me !
Thanks !!
But I still hope that number to display on preform App
