Resin specs
I seem to not be able to find properties of the resins.
Will gray (grey) burn out completely for lost wax casting?
What resins will work in oil, water, silicon grease?
These are for two different applications.
Any help on this? Or even pointers of where I can find the info out?
You’ll find some limited information on the technical data sheet for each resin. These are available on the Formlabs website here.
Thank you! that helps…by the way, my middle name is Wakefield, family name.
