Got this in my email, looks like it might work with the printed parts. Curious if others have used it before and how are the results?
http://www.caswellplating.com/plating-kits/electroless-plating-kits.html?cat=332&utm_source=sendy&utm_medium=email&utm_content=email%20newsletter&utm_campaign=email%20newsletter
You can plate with very thin copper at room temperature without electricity (it’s really a coating). You need to plate with copper first regardless of what electroless kit you want to use (nickel, tin, etc.)
The electroless kits (step 2) require a bunch of heat to be effective. You may need to use the high temp material for it to work without melting/distorting the part.
The first kit is: http://www.caswellplating.com/electroplating-anodizing/plating-non-conductive-parts/electroless-copper-kit-1-pint.html
Says 100°F which the Formlabs resins will hold up to without any problems. I have only plated metals in the past. Thought this might be useful.
Thanks
great… another thing to spend money on that I dont need because I never use my printer anyway
haha
