New Measure Tool in PreForm 3.53!
Hi PreForm users! PreForm 3.53 just dropped, and comes with a new feature, the Measure Tool! Quickly validate dimensions and clearances by measuring precise distances between any two points in your scene, with ΔX, ΔY, and ΔZ components in the summary panel, eliminating the need to switch to external CAD software for simple dimensional checks.
At the top right of your viewport, you’ll notice a new Measure button (Keyboard shortcut: M)
What's New in PreForm 3.53
When clicked, you will notice a preview pin on the surface of the mesh under your mouse.
Screenshot_2025-10-21_14.21.20
Clicking once will place the first pin, and clicking again will complete a measurement. Holding down shift for either measurement point will enable vertex snapping, so you can more accurately select corners and edges.
Over on the side panel, you will see the measurement along with a breakdown of the ΔX, ΔY, and ΔZ components, with buttons to copy the numerical values to your clipboard. Clicking the ruler icon Screenshot_2025-10-21_14.28.16@2x will quick-toggle between mm/inches. (The default unit shown will depend on the units the measured model is set to)
The measurement will persist on your models where you placed them, so you can translate, rotate, and scale your measurements and have the values update in real-time.
You can use this feature to measure minimum feature thicknesses, part clearances, hole sizes, tolerances, distance between support points, and more! It can also be used alongside the Section in all Axes feature from the previous release to measure hard-to-reach areas of your builds.
Please give this feature a try and leave your thoughts/feedback below! Happy to chat further with our incredible users and learn how we can make PreForm better for your workflows.
Watch the full “What’s New in 3.53” video here:
After opening the Job Setup window the Measure dimension display is still displayed?
When using the View Cube clicking the Top face of the cube doesn’t reset the view Z orientation to a default Top? It just aligns it to the nearest orthogonal view? Example showing upside down after clicking.
Clicking Top or Bottom of the view cube doesn’t focus/zoom the window to the part? Home, Front, Right, Back, and Left all focus/zoom to the part as expected?
Thanks for the quick feedback @Andrew_W!
This has been noted as a bug fix for a future release. In the meantime, closing out of the Measure Tool before opening Job Setup will prevent the measurement from blocking your view.
I’m not too sure I understand, are you saying that you’d want the top face view to always orient 180º from the screenshot you sent? (with the “TOP” text facing right side up)
Could you possibly take a screen recording of the issue? And could you try if having the part selected vs deselected makes a difference? Thanks again!
@henryqiu Video shows clicking the cube doesn’t always focus to the part, selecting the part first makes no difference. Also clicking Top should alway orientate to Top, not Top upside down as shown in the video as well.
nice feature for those who design prints without a modeling program.
Rhino 8 has a measuring feature that I use to make sure parts fit or are the size I want.
